operator
Configures a unique name of the administrator or operator
responsible for the configuration and management or the hotspot. The name can be configured
in English or in any language other than English. When the name is specified in English,
the system allows an ASCII input. If using a language other than English, first specify the
ISO-639 language code, and then specify the name as an hexadecimal code.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
operator name [<OPERATOR-NAME>|iso-lang <ISO-639-LANG-CODE> <OPERATOR-NAME>]
Parameters
name <OPERATOR-NAME> |
Configures the operator‘s name in English
- <OPERATOR-NAME> – Specify the operator name in
ASCII format. The name cannot exceed 252 characters.
<OPERATOR-NAME> |
Configures the operator‘s name in any language
other than English
- iso-lang <ISO-639-LANG-CODE> – Specify the three-character
ISO-14962-1997 encoded string defining the language used in the Code
field. For example, chi or spa.
- <OPERATOR-NAME> – Specify the operator name in Hexadecimal
nx9500-6C8809(config-passpoint-policy-test)#operator name exampleoperator
nx9500-6C8809(config-passpoint-policy-test)#show context
passpoint-policy test
access-network-type chargeable-public
connection-capability ip-protocol 2 port 10 closed
nai-realm example
eap-method 1 ttls auth-param vendor hex 00001E
eap-method 2 rsa-public-key auth-param credential cert
net-auth-type accept-terms url www.test.com
3gpp mcc 505 mnc 14
Related Commands
no
Removes the operator's name configured for this
passpoint policy
